product picture
Hydro Systems Melissa 6636 Tub
pin
Gentle radiuses and ample bathing room make the Melissa a classic tub with great functionality. With a narrow deck all around, this tub provides the maximum bath well for the size. Must be set in mortar base. Available in multiple sizes. This bathtub features Hydro Systems legendary 99/9 Year Warranty, it's components are built locally in North America. Please note, custom orders may not be returned. More information regarding the return policy of your custom-built Hydro Systems product is available here. All Melissa 6636 Tubs Feature Acrylic models finished in 1/8" thick layer of deep lustrous acrylic Extra thick reinforced fiberglass Integral E-Z Level platform facilitates installation Non-skid bottom Components built in North America Hydro Systems' 99/9 Year Warranty Must be set in mortar base Available in multiple sizes. Whirlpool Tubs also Feature 5 Available Option Packages 6 Fully directional adjustable PVC jets Hydro "Soft Touch" electronic control panel Sound Dampening Motor Pad Anti-vortex safety suction Color matched system trim HydrOzone ozone sanitation system Self draining pump and system 2.25 HP Single Speed Pump Thermal Air Tubs also Feature Heated Backrest 1.0 HP variable speed blower with 600 watt heat with a smart purge system 6 Fully directional adjustable PVC jets Hydro "Soft Touch" electronic control panel Sound Dampening Motor Pad Anti-vortex safety suction Color matched system trim HydrOzone ozone sanitation system Self draining pump and system 2.25 HP Single Speed Pump Designer Series Melissa Tub Spec Sheet Note: This item usually ships in 14 business days from the manufacturer. Please allow an additional week for shipping.
Get the Lowest Price
